Ana içeriğe geç
Google tarafından üretilen ilk nesil internet üzerinden yayın izleme cihazı. Temmuz 2013'te piyasaya sürülmüştür, H2G2-42 model numarasıyla tanımlanır.
Red light no matter what?
Hi, I have a google chromecast and when I set it up everything worked perfectly. I unplugged it for the night and then I plugged it back in and it had a red light. I tried factory resetting it but the light still stayed red and the reset button is not stuck. Anything that I can do?
Thanks
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try swapping out the USB cable that comes with it, apparently several people were given a cheap faulty USB cable that would stop working after a day or two. Many have found salvation by using a known good USB cable. Let me know if this doesn't work. Oh as far as the reset button you should feel a definite click, if you don't press the button repeatedly to loosen it up.
Bu yanıt yardımcı oldu mu?
Puan 4
2 Yorum:
Changing the usb cable worked for me. thanks so much!! such a simple solution but had me stumped. thanks again.
tarafından
I have an original 2013 Chromecast and it just stopped working now - July 2022! I know this is an old post, but just commenting as I came across this, and tried changing the cable as a last attempt before throwing it away and it worked!
tarafından
Yorum Ekle
Hi
Mine did the same. My Ccast remained plugged in and working great for a few months. Then one day, I noticed the LED was off.
I have tried many power supplies and cables. No luck. Even with a USB inline volt and ammeter plumbed into the supply. It shows no current draw from the C-cast.
Anyone else have this. ??
Puan 1
Yorum Ekle
i am using the chromecast 2 audio only mode with 4k hdmi converter, red light always blinking bt it extracted audio perfectly.
Puan 0
Yorum Ekle
When I turn on the chrome cast the white light is blinking. But it is not showing in my device
Puan 0
Yorum Ekle
Yanıtını ekle
Ted Mayer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 47
Her zaman: 27,295
