Ana içeriğe geç
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Soru Tümünü görüntüle
Will not switch off
My 3gs will not switch off on the top button. Will not reboot either, which normally sorts minor problems out. When I try to reboot by depressing and holding the off and home buttonds I get 'Voice Control' instead of option to power down.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You power button sounds like it's broken..
Go to settings then general then accessibility and click on that turn the assistive touch option on..
A little circle will appear press that and press device now you will see lock screen no put your finger on it and hold til the slide to power down appears
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Hi con
Worked perfectly, many thanks.
Was stumped when trying to turn it back on, put it on charge which did the trick!.
Is there another way if I did not have access to a charger?.
tarafından
No charger is the only way to turn it on unless you fix power button
tarafından
Thanks again con, you have been a big help.
tarafından
Yorum Ekle
Yanıtını ekle
Mike sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 169
