Ana içeriğe geç
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
Replacing the motherboard with 8GB RAM, can I?
Hi,
My motherboard is gone due to a spill (advice: if you spill something in the macbook, just bring it in a repair shop for cleanup, as mine lasted 6 more month but would have been OK if I had cleaned it properly).
Anyway, since I am replacing logic board and top cover anyway, I thought I might put in 2.0Ghz i7 with 8GB of RAM instead of the original 1.86Ghz and 4GB.
Are there any incompatibilities between the logic boards of the same year if I put higher end internals? Given that the logic board that I replace with is from a MacBook Air 2012 A1466 same as mine..
Any thoughts? :)
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
sviests, for as long as you stay in the same year/group you should be okay with a swap. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Yanıtını ekle
sviests sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 2,031
