Ana içeriğe geç
2.26 or 2.4 GHz / White plastic unibody enclosure
644 Soru Tümünü görüntüle
No Backlight after spilled coffe on the keyboard.
I spilled coffee on the keyboard, I cleaned inside with deionized water and now the monitor works but not the back light. What can be the reason? What can i do to fix it?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
  1. Check that brightness setting is above minimum
  2. Reset SMC
  3. Reset LED backlight controller by pressing Control Shift Eject keys, then wake up system by pressing any keyboard key.
HIH
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
I tried everything and it is still not working.. does it mean that it is an hardware problem? is there something else that I can do?
Thanks
tarafından
Sure sounds like a hardware issue then. Can you verify the power gets to the LED controller board?
tarafından
Yorum Ekle
I have the same problem (also coffee spill), and there was more damaged than the backlit. It was completely dead. Meanwhile I changed an IC on the logic board, so now everything seems to run except the backlit and the battery-charging.
I tried the software resets from Richdave, and pluged in another display. No change.
So where can i start now to fix the issue?
Puan 0
Yorum Ekle
Yanıtını ekle
strade sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,234
