Ana içeriğe geç
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
Thermal Interface -Video Controller ASD Error
After recently replacing my GPU card and chip, I ran Apple Service Diagnostic 3S123 and discovered I have an error that states: Thermal Interface -Video Controller:G92gt (test #4) -TIM Test 75 percent Gardband-Check that CPU heatsink is properly attached, using product spec theta dh + 75 percent guard band.
Any suggestions on how to fix that? I can't find anything online about it. I don't even know where to look on my machine for that item.
Bu iyi bir soru mu?
Puan 1
1 Yorum
I was careful with the screws and believe I am using the correct ones. Could you take a photo of the screws I should be using if you have them handy? I want to verify I am using the correct ones.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
When you replaced the card and GPU did you use thermal paste? I'd also contact Brickfence and ask them the same question since they did the repair.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
I am using thermal paste and just replied it to the CPU portion again after the error/fail notice. After I reapplied it I got the same error message. Now I am wondering if it is the quality of thermal paste I'm using. I just emailed Brickfence too see what he suggest. Thanks for the suggestion and your prompt responses! I really appreciate it.
tarafından
I've seen these types of error when the wrong screws are used (or missing) from the heat sink. I'll be interested to see what brickfense suggests.
tarafından
Yorum Ekle
Lynnor, this is not an answer but I can not add images to comments. This is to support "mayer"'s answer.
Puan 1
Yorum Ekle
Yanıtını ekle
Lynnor sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 961
