Ana içeriğe geç
HP'nin Nisan 2013'te piyasaya sürülen 7 inçlik tableti, ilk sürümlerine kıyasla bazı yükseltmeler içeriyor. Bu cihazın onarımı diğer Android tabletlerinkine benzer olup sadece tornavida ve bir ayırma aparatı gerektirir. 8 veya 16 GB kapasiteyle / Kırmızı veya Gümüş renk seçenekleriyle sunulmuştur.
How can I replace my HP Slate speakers?
I damage the speakers in my HP Slate and tried replacing them on my own but got stuck. I've gotten to the point in the disassembly where both speakers are unscrewed from the inside and are next to the charging port, but I can't seem to take them out. Am I missing something or are the speakers just stuck to the body of the tablet? I want to be careful not to break the charging port when I take them out. Or do I have to remove the charging port first? And if so, how?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
To ensure there is no damage caused to the motherboard, remove that before any further action. Once that is done, lift up the charging port to remove the left speaker (looking at the tablet from the back).
In order to remove the right-side speaker, remove the volume rocker, carefully lift up the surrounding metal back off the device, lift the silver tape from the charging port to remove the second screw, and then remove the charging port. This will give you access to the second speaker. If you have any confusion about this process, the images in the HP Slate 7 speaker repair guide can assist you further.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Just make sure you lift the battery out and the charge port assembly. The speakers will lift out easily while you are doing this.
Puan 0
Yorum Ekle
Yanıtını ekle
Davis Muxlow sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 445
