Ana içeriğe geç
"PS2" olarak bilinir, Sony tarafından Japonya'da Mart 2000 tarihinde satışa sunulmuş altıncı nesil bir oyun konsoludur. Amerika onu 2000'in sonuna doğru SCPH-30000 ile gördü. Bu cihazın tamiri sadece genel araçları gerektirir ancak tamir zorlayıcı olabilir.
Why does my PS2 show a 'Brwser/System Configuration' screen on some ga
My Playststion 2 opens to a screen that says 'Browser/ system configuration' screen on some of my games. It will not load game when this screen pops up. It also says to use a Playstation or Playstation format game. What does this mean??
Bu iyi bir soru mu?
Puan 16
11 Yorum
When i play any game nd when the game is start so my screen pop up and in the bottom it shows black screen nd the game is pop up i play on half tv nd the half tv is black plz tell me any solution
tarafından
It's because your disk tray is too high up put pressure onto the top of the tray with the disk in and lid closed and it will load up. If it stops when you remove pressure keep something heavy on it
tarafından
@Baconchops09 thank you!!!!! I have thrown away 4 ps2s and was getting ready to toss this one! Ur 'trick?' Worked! Thank u!!!!!!!!!!
tarafından
So i turn on my ps2 and when i get to the home screen all i mean ALL the words are pink, blue or gray . Also when i get into the game the words are so out place that you can't even read it. Someone please help me.
tarafından
So i turn on my ps2 and when i get to the home screen all i mean ALL the words are pink, blue or gray . Also when i get into the game the words are so out place that you can't even read it. Someone please help me. by max
this is maybe a BIOS corruption and it means that your device is pretty f..ked up
tarafından
6 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Are you trying to play copied games ?
if not - it's possible that the laser has problems to read the games.
most people are saying thet the laser is defective and needs to be replaced.
but i had a few ps2's with laser problems and all of them were only dirty - the dust is "burnt" on the laser. i've cleaned them with a slightly wet microfibre cloth and that was it - the are all running without any problem
Bu yanıt yardımcı oldu mu?
Puan 10
9 Yorum:
Then it shows READING DISC, DISC CANNOT BE READ
tarafından
I'll retry doing that.. But isn't a microfiber cloth gonna get all of its fiber sticker to it like dust as well? Thanks
tarafından
PD के game nahe dekha ta hai serf browser or confregration dekhata hai please help
tarafından
I used to play a 4 disk game on my ps2 with no problem and had saved 6 files on my memory card. I lost the game and bought a new set of it, but it won't let me save or load. The message says memory card not inserted. I tried it with my tekken 5 game and it works just fine. What do I do?
tarafından
Please it is a new one a man in my area told me that my pile needs configuration please is that true
tarafından
4 tane daha yorum göster
Yorum Ekle
Try to buy a new MEMORY CARD. Some ps2's are starting the console from memory cards. Your system configuration in memory card might be corrupted or deleted.
Puan 6
4 Yorum:
pls I use to play my ps2 with memory card and I travel and come back I try to play my ps2 again but is not reading my memory card it only shows me browser/configuration settings pls someone should help me pls
tarafından
Put in a memory card and everything worked perfectly.
tarafından
My PS2 shows only browser/system configuration what can I do
tarafından
I unscrewed the casing and wow the amount of dust it had gathered just by being in a carrier bag tucked away, I only use when I work away & not used since last November. Would be easier to get a Henry vacuum up against the fan at the back and let the vacuum do it's magic. PlayStation works fine now.
tarafından
Yorum Ekle
Yanıtını ekle
wade webb sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 21
Son 7 gün: 128
Son 30 gün: 470
Her zaman: 190,425
