Ana içeriğe geç
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
showing 0146 error
hi
in my system also showing 0146 error but there is no any operating system install in previouslly
when i am trying to boot it will show
Winows failed to start . A recent harxware or software changes might be the cause .to fix the problem:
1) Insert your windows installation disc and restart your computer.
2) choose your language settings and then click next
3) click repaire your computer.
If you o not have this disc , contact your system administrator or computer manufacturer for assitance
status:0x000000f
Info :the boot seletion faild becouse device is inaccessiblle.
if there any solution for above error then plz post that ....
and i also change SATA setting SATA Mode under drive options to ATA from AHCI and save settings. but not working .....
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
ganesh, you obviously already tried all the common steps. This error code most often correspond with a failed hard drive. To repair it you will have to replace your drive. Hope this helps, good luck
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
ganesh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 107
