iPad 2 Home button intermittently working after Digitiser replacement
• (1) Heavily damaged and misshapen rear housing on the bottom right (next to Wifi antenna):
• (2) Another dent found directly over the dock connector (this does not seem to effect charging):
I removed the old damaged digitiser and replaced wifi antenna but the damage to the outer housing I believe is causing the home button contacts to not touch fully. There is intermittent response when pressing hard, I may need to check alignment and reassemble. Would this dent directly effect the contacts or is it related to the alignment / adhesive?
Also, the damage near the wifi antenna was quite severe so I replaced the wifi antenna. However, the wifi does not find any connection. Could this be due to the bend in the outer housing on the bottom left or a contact issue with the digitiser? I will recheck connections on the main board just incase I've missed anything.
Any other ideas?
Thank you!
Will
Bu iyi bir soru mu?
