Ana içeriğe geç
Samsung Galaxy Note 4G olarak da bilinen Samsung SGH-I717, Samsung Galaxy Note LTE 2 Ocak 2012’de piyasaya sürüldü.
Phone power off alone,and vibrate.
My phone come on for a few min. then power off alone or the option to power off my phone pops up on the screen. when phone power my phone continue to short vibrate. What could be wrong or what should I do?
Bu iyi bir soru mu?
Puan 16
1 Yorum
My phone Micromax canvas colours 2 is switched off and is vibrating continuously. I have kept it near a bottle in the storage of my scooter. What to do ? It's screen is also coming white from sides.
tarafından
Yorum Ekle
9 Cevap
Filtre ölçütü:
Seçilen Çözüm
remove and reinset the battery, press the volume up key, home button and power button simultaneously. you can see recovery console. format the cache partition and select reboot. fault may solve. Note: dont format the flash because your all data will be lost
Bu yanıt yardımcı oldu mu?
Puan 13
5 Yorum:
If my Phone haven't removable battery and Power button not worked .. then what can I do
tarafından
Rohit, this is about Galaxy note. if you have any trouble with your phone you can ask a question mentioning the model info. we can help you to fix the phone !
tarafından
I got LG G3 my phone suddenly restart.. with viberation
tarafından
My phone model samsung one7 pro.Often the phone shutdown and keep vibrating for 20 or more seconds.. Now what can I do to fix the problem?
tarafından
My phone is realme c15 shutdown itself, the alarm is ringing but it's not opening, what can I do the battery is unremovable.
tarafından
Yorum Ekle
Jennetta Davis, start by replacing the battery. This will also provide you with a known-good starting point for further trouble shooting. For now, it does sound like a battery issue.
Puan 2
Yorum Ekle
It's not the battery it's the power button:
http://www.blogtechtips.com/2014/04/06/s...
Puan 2
1 Yorum:
Pls have not satisfied with galaxy note issue my own keep on restarting over and over till it will drains up the battery i'm tired.
tarafından
Yorum Ekle
yes, your galaxy note 3 may have a battery issue
____________________________________________________
achat galaxy s5
Puan 0
Yorum Ekle
Samsung galaxy s4
Sometimes all at once the phone will start to vibrate and won't stop , likes it's stuck on vibrate. only way to stop it is to turn it off . Any advice
Thank you !!!!
Puan 0
2 Yorum:
i would like to know the answer to this as well
tarafından
Yorum Ekle
i have samsung galaxy note edge.. its working properly but when i switch it off, this phones starts vibrating continuasly , and i cant switch it on with power button, i need to connect to charger then it will be on... what is the probelum in phone , kindly reply
Puan 0
1 Yorum:
My Galaxy Note 4 suddenly went off while charging on 40%. The screen then displays the charge symbol with no battery indicating that the battery is zero but then it tries booting itself which then vibrates, goes off and shows empty battery level. I thought it was a battery issue so I replaced the battery and it still does the same. It won't boot. keeps indicating empty battery though on other Note 4, my battery shows 100% charged. I can't even enter hard reset mode with the keys because you try and the phone goes off and restarts. No physical damages or what so ever. Only a month old.
tarafından
Yorum Ekle
my s7 edge phone is vibrating automatically after every hours at 45 mins.I did stop all notifications for apps and stopped vibrate options of phone setting too..still its vibratiing.so now what I should do??
Puan 0
Yorum Ekle
mine was doing the same thing, changed batteryy and it worked
Puan 0
Yorum Ekle
My Galaxy 6 edge is stuck on fab lock on , odin mode, downloading -do not turn off target .__…..
Puan 0
2 Yorum:
Good day guys, my infinix hot 8 x650b is not displaying, not powering on, but vibrate profusely. The charging port is okay when charging it doesn't display just the charge indicator light. I try the power button+volume down nothing displayed. Please what can I do?
tarafından
I have a galaxy 5 samsung it constantly vibrates while it is plug in.It shows no battery life ,when i take the battery out it shows power but it just start"s to vibrate again,What should i do.It vibrates and flashes to while it is charging,could it be my battery or my phone,i had my phone now for a few years but i took care of my phone since i had it.
tarafından
Yorum Ekle
Yanıtını ekle
Jennetta Davis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 77,767
