We have quite a few of the '10 & '11 15" models (approx. 200) all have been quite reliable.
The only issue we have had is controlling (force) which graphics services to use per a given app. So the built-in Intel graphics can be over-ridden using instead the AMD Radeon HD 6750M.
Apple's desire to be auto-magic is a bit flawed here, as it is expecting people to need the same thing. In truth our needs are sometimes opposite to their design goal (needing the better GPU). I can't fault Apple for trying to make a dual GPU system work based on power Vs users needs, as the general public most likely doesn't understand the ramifications of using a given GPU unit. I suspect that is why Apples newer systems are moving away from the dual GPU setup (at least the built-in GPU's are much better in todays models).
Here's a good write up on how to do some control while it's not perfect it does help: Unibody MacBook Pro Q&A - Updated July 27, 2012
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
2
Can you give us the last four digits of your serial number so we can correctly identify your system.
Dan tarafından
Hello,
Last four digits serial no = DV7L
Thanks
MaDa tarafından
2.2 GHz Core i7 (I7-2675QM)
Intro Date: October 24, 2011 Disc Date: June 11, 2012
Order No: MD318LL/A Model No: A1286 (EMC 2563*)
Subfamily: Late 2011 15" Model ID: MacBookPro8,2
Std RAM: 4 GB Std VRAM: 512 MB*
Std Storage: 500 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
oldturkey03 tarafından
What are the issues you are having with this board?
White line into screen and sometimes the screen spilt to two now i'm unable to boot up my Macbook or even reinstall OS it get stuck and get over heat
MaDa tarafından
2 tane daha yorum göster
