Ana içeriğe geç
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Soru Tümünü görüntüle
Can I remove or disconnect the webcam from unibody MacBook?
I need the isight camera to be off in order to bring my laptop to work, and to disconnect or remove the isight camera is the only way i could.
Is there any guide to simply remove the webcam from the laptop and then put it back on when i resign a year later.
*Buying the laptop a year later is not acceptable, i need it for work now.
Thanks in advance
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here is a link for a teardown for a 2009 15" unibody that should be close to yours. Follow the link to step 7 which is to disconnect the camera cable from the logic board. You could then tape it for safeties sake and your camera would no longer function. Hope this helps. Ralph
MacBook Pro 15" Unibody Mid 2009 Display Replacement
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
should work but the workplace will probably want to check it everyday to see if it's been reconnected. Better to just remove it. +
tarafından
I wonder if the company could just place a security seal of some sort over the camera lens. Ralph
tarafından
Yorum Ekle
I used a silver-grey colored paint pen to cover the lens completely, and fill in the tiny microphone holes on the side of my MacBook.
Puan 0
1 Yorum:
I also discoonected it internally, but they cannot see that.
tarafından
Yorum Ekle
Yanıtını ekle
Batman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 8
Her zaman: 5,483
