steam boiler heats water...has funny smell
The machine heats water and boils the water to steam....the steam has a pungent smell....not sure if it needs to have system cleaned....if so how do you clean it?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
When steaming milk it's possible for some of the milk to be drawn up the steam pipe at the end of the process. If enough of the milk gets into the boiler it will cook on the heating element and result in smelly steam. The only way to get rid of it is repeated heat/flush cycles or replace the heating element. To prevent this, every time you steam milk, when you're done remove the pitcher and open the steam knob again for a few seconds. This will clean the wand out.
Bu yanıt yardımcı oldu mu?
how do you do that? I have the same problem except it is affecting the taste of the milk as well.
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 16
Her zaman: 1,134
Have you been using tap water or bottled water?
mayer tarafından
I have always used tap water
Henry Ricciuti tarafından
What city and country do you live in?
mayer tarafından
