Ana içeriğe geç
Grey Screen is display saying hold power button to restart
When I turned on my iBook, everthing was operating as it normally had and booted without any noticeable problems. After a short time the screen went gray and there was a power button symbol in the background. It states to hold the power button to restart the computer. I followed the instructions and it continues to direct me to do this process over and over again.
Can any one help/guide me with some trouble shooting techniques?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
3 Yorum
thanks
tarafından
Hi, how many time do I repeat this solution. I tried a least five times and the gray screen still pop up?
tarafından
I try this method multiple time, the gray screen pops up and freeze until I restart it. Is my iBook unrepairable or is there another solution? Please HELP ME.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This is called a kernel panic. Insert your system disk in the optical drive and start up holding down the "C" key. Go to the second screen and the pull down menu will appear. Go to Utilities - Disk Utility and repair the hard drive. Keep doing so until it runs clear. This failing, you will need to reinstall the system.
Bu yanıt yardımcı oldu mu?
Puan 1
5 Yorum:
Thanks I will try it now.
tarafından
Agreed--he may also want to reseat his ram. + Ralph
tarafından
How do I go about resetting the ram + Ralph?
tarafından
Hi, Just remove your ram and check the sockets and then reinstall the memory one stick at a time. Ralph
tarafından
I tried this solution as well, and my extra memory stick is not recognized. Only the one on the mother board is being use/ recognized.
tarafından
Yorum Ekle
Yanıtını ekle
kazadia sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,777
