iPhone 5 Not Charging, After Replacing Battery & Charging Port?
I've been in the Apple repair business for almost 3 years now and I'd have to say I'm stumped on this one, can anyone help me out please?
I have an iPhone 5 that would not charge, after replacing the battery with a new one along with the charging port, I still can not get the iPhone to charge let alone display any sort of charging symbol or anything. I went very carefully when replacing the charging port and had no issues. Can anyone give me an idea as to what to check or even replace that can fix this issue?
Thanks
Adam
Bu iyi bir soru mu?
7 Yorum
"any sort of charging symbol or anything." so what do you see?
oldturkey03 tarafından
Just replaced the logic board with one that i knew worked. It appears your both right the logic board that i used to replaced the one that wasn't working is working just fine. Now this brings me to my next question, does iFixit repair Logic Boards with this issue or will i need to find another business that does, if so who?
Adam Schultz tarafından
Adam Schultz, ifixit does not do repairs. You can get parts and advice on here, but no repairs.
I have the same problem.
I put in a new battery.
Then I changed the charger port. (The old one was worn and not always connecting with the lightning cable)
Now - It doesn't charge, but it works if plugged in (i.e. NOT mobile)
I have opened it up and checked the connections, but it all looks good.
Any suggestions welcome.
PS: (It either shows 100% or 1% in the battery readout, but I think that is a separate issue. I reset the iPhone and that issue was fixed for a while)
graham tarafından
OK. Ive just been reviewing the assembly of the charging port using:
https://www.youtube.com/watch?v=joM5UwSR...
(iPhoneRepairMiamiBeach dot com youtoobe channel charging port)
At 4minutes 10 seconds in to the video he says "make sure you do not lose these washers". Now I do not have the tiny washers that held in the charging port. They fell out the first time I did it and I couldn't see where they had come from. I then lost one, so I hoped it might not be important.
Does anyone know what these washer do? And if they are significant to this problem?
graham tarafından
2 tane daha yorum göster
