The touch screen is unresponsive
I keep pushing on the touch screen but nothing moves? What should I do?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The most likely problem is a loose connection on the inside.
Check the connections of the ribbons on the inside of the device. Follow the motherboard removal guide to get to the ribbons.
If this doesn't work, the digitizer may need to be replaced. However, a guide is currently not available for that. To replace the digitizer, one would follow steps similar to the screen replacement guide, but put the components in a new digitizer.
Kılavuz
Zorluk:
Zor
15 - 25 minutes
Kılavuz
Zorluk:
Orta
30 - 45 minutes
Bu yanıt yardımcı oldu mu?
my tablet is in a sleep mode and will not wake no matter what I do.
Tried on and off, reset button and power and up volume button at the same time and nothing changes
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 9,690
4 Yorum
It will work with A mouse
hmrogers01 tarafından
the glass is cracked will this keep it from working
It isnt working not alittle.
Richard James tarafından
my screen is cracked and the same thing happening how do I fix this
Fantasy Anime Lover tarafından
