Ana içeriğe geç
The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
91 Soru Tümünü görüntüle
Disc not spinning in GameCube
Hi, my console is showing a NO disc error, i found that the laser works but the disc is not spinning.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 7
1 Yorum
My GameCube continues to spin disc and never stops even when i open it what to do
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I found an old Gamecube at a second-hand store going really cheap. The catch was, the disc would spin up, and then stop again (with no disc message/indication).
If the drive detects no disc, it won't spin the motor. So if your laser is dying, and it cant see anything, it wont spin the disc.
So it is possible that the laser is dying/almost dead, but there ARE guides out there that may help with this; just google "gamecube laser calibration" and hit the first link.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
This was my issue personally. Apparently my laser was so dirty it couldn’t see the disk! Thanks for the advice.
tarafından
Yorum Ekle
I've seen this before on some devices, usually it is a burnt out drive motor. but to be sure when you power up listen to see if you can hear the drive, since it will stop spinning when you open the cover.
Puan 1
1 Yorum:
I'm sure that my disk Is not spinning, because I've been listening to the motor. My laser is clean, so I know that that is not the problem. Also, other disks are working and spinning properly and working just fine. This disk may have minor scratches on it, but no major. Please help.
tarafından
Yorum Ekle
Indeed, I had the same problem with my GameCube. The laser module died, but the spindle motor and laser carriage worm drive motor were both fine, as I could hear it both spinning briefly and trying to seek, but finding nothing. Maybe your lens is just really dirty? Try cleaning it with alcohol.
Puan 0
Yorum Ekle
There is a switch near the disc drive, and you need to make sure that the switch is turned on, and that causes the disc to spin. It needs to be held down, and usually it is but maybe something fell off, so try to open the GC and see if the switch is held.
Puan 0
6 Yorum:
what switch???
tarafından
nevermind, I know what you mean. I found my issue, I broke one of the pieces on that switch!
tarafından
what switch?
tarafından
The switch is just behind the optical drive on the right hand side. It's got two toggles on it, hope this helps.
tarafından
What's the optical drive
tarafından
1 tane daha yorum göster
Yorum Ekle
I tried putting slight pressure on the top of the console with my hand while bootin up the cube and it resolved my issue. Keep pressure on it until the game loads to the game's menu, otherwise ur bad
Puan 0
Yorum Ekle
It's not reading the disc
Update (04/23/23)
The laser not reading the disc
Puan 0
1 Yorum:
@gqs4dlmohte2mwy what have you tried? Cleaned the laser first?
tarafından
Yorum Ekle
Yanıtını ekle
Davidmejia sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 23
Son 7 gün: 126
Son 30 gün: 636
Her zaman: 59,438
