Screen popping out of cover
Screen keeps popping out of aluminium casing when opening the top. After closing you can push it back together again.
Machine works perfectly.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
HI Peter,
Is your MacBook Pro new? Did you change the protective glass?
Well it looks like your bezel is coming out most likely because the adhesive does not hold anymore!
My advice remove the protective screen, using the Pro Tech tool kit, get some proper adhesive and fix it back...
I have just replied on another post about changing just the screen, go and see it you might get a more accurate answer ;)
If you like my answer, just don't forget to score it...
Thanks,
Max
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 503
