Ana içeriğe geç
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 Soru Tümünü görüntüle
Display screen colors distorted
My little sister dropped my iPad 2 on the floor. The colors on the screen are a bit out of their normal color. The screen looks a bit also like an old version of a t.v. with scratching lines. The keyboard is green. Once you unlock the iPad the screen looks like the colors of a 3-D screen. Help please! http://m.youtube.com/watch?v=UXfSdG-CwYU
Bu iyi bir soru mu?
Puan 190
111 Yorum
It worked! Who would think 10 whacks on the back would fix it but it did! Thank you..........
tarafından
The screen is green. Tapping did not work.
tarafından
OMG it worked. Thanks
tarafından
I left my iPad in the car and it overheated then chasing my screen to be distorted in color. I let it cool off for a while in hopes that's what it was. Whacking it really helped. THANK YOU SO MUCH!!
tarafından
my fathers ipad is doing the same thing like the version of and old tv. Help!
tarafından
106 tane daha yorum göster
Yorum Ekle
13 Cevap
Filtre ölçütü:
Seçilen Çözüm
Before you go replacing the LCD try giving the back of the iPad a solid smack with your hand. There are many cases where the iPad has been dropped knocking the LCD cable slightly loose. Hitting it may knock it back in place. Do a search on this site and you'll see many examples of this.
Bu yanıt yardımcı oldu mu?
Puan 90
103 Yorum:
Found out from other forums that way to fix it is to turn it over and give it ~10 slaps on the back! Believe me it works ( got it off other forums )
tarafından
Can confirm the smack on the rear case does work
tarafından
Lol that worked I can't believe it!
tarafından
I was extremely skeptical of this, specially because mine seemed to be much more skewed than what others seemed to be reporting. I tried it and it improved drastically but still wasn't back to normal so a few more pops and presto, it was like magic! Who ever said violence solves nothing!
tarafından
Well this definitely works. Dropped mine just now and was in despair - until I decided to give it some good smacks....and fixed.
tarafından
98 tane daha yorum göster
Yorum Ekle
A hard smack on the back--left side will set it right---for now. Ultimately you'll need to open that sucker up and properly re-seat the LCD cable.
Puan 31
35 Yorum:
thank you it worked
tarafından
this is not working for me. Do I need to get the cable properly reseated?
tarafından
Make sure it's on the left side, middle to top. Worked great for me.
tarafından
Omg it actually worked!!! Don't think this is a hoax--dropped iPad last night and colors were totally off. Three good whacks to the back left and totally back to normal! Wow!
tarafından
OMG indeed! I dropped it in its case and the colors were totally off, scrambled, it wasn't usable. Ten whacks to the upper middle left and presto! Woohoo! Saved me an expensive repair bill. GREAT advice!!!
tarafından
30 tane daha yorum göster
Yorum Ekle
So I just knocked my iPad off the side and my screen went very fuzzy and the colours changed,I read this and I smacked it a few times on the back and nothing seemed to have happened,I then smacked all parts of the back of the iPad,I turned it back round and it had looked like nothing had happened however when I was scrolling down to read a few more of the suggestions,I had started panicking at this point however I was scrolling down for more for approxametly 20 seconds,I looked back at my screen to try another suggestion and then it was SUDDENLY back to normal if not better I 100% recommend trying this as it worked an absolute dream for me x
Puan 0
2 Yorum:
Did not work for me
tarafından
It did just wait for a while …
I was reading this and I left safari and boom
tarafından
Yorum Ekle
Can I get it changed at the istore? It's less than one year old.
Puan 0
Yorum Ekle
Yooooooooo this is crazy but me and my roomate were making crazy videos and my ipad fell...started getting distorted. I thought it was done for. I joked that if i just slapped it like it fell maybe it would magically work. Googled ipad display problems and found this site. Blown away at all the actuall responses to just smack it....butttteerraa ya girl did it and my baby is back in business!!! Took about a min bit it worked!!!!!!!!!! Hallellujah
Puan 0
1 Yorum:
You are a life saver. Smacked 20-30 times and left it for over 2 mins aaanddd Its alive
tarafından
Yorum Ekle
Someone please I need somebody’s help NOW! My iPad Air 2 just dropped today and I can’t get it fixed, while I was watching YouTube videos, I thought that the colors looked weird, and that was I thought. My entire iPad has been punished with blue, pink, fuzzy green, and red colors. I was looking up here, and the only way is to smack and whack it. I tried it and it can’t do the trick. I did it almost 100 times roughly whacking it, but it just made it worse. Please help me here, I can’t deal with flashing colors.
Puan 0
2 Yorum:
Mine too!! God! It actually didn't work ☹️☹️☹️☹️ What we do now???
tarafından
take it in for repair so the LCD cable can be put back in place.
tarafından
Yorum Ekle
tried tapping the back of my iphone but it didn’t work at all.
Puan 0
1 Yorum:
this is for IPads... the phones are more sturdy and have different set up... take it for repair... to have the display cable securely connected.
tarafından
Yorum Ekle
wow, i was starting to panic
i did both a few solid slaps and a few punches (but hitting with the soft squishy part of my fist not my knuckles) but that didnt get me anywhere, so after reading through all these comments i though, every one is saying to hit it solidly on the left hand side, so i took a hit near the bottom and the on the top of the ipad (on the back obviously) with the squishy part of my fist and boom, all the colours clicked back into place
looks live ive got to start taking better care of this thing XD
Puan 0
Yorum Ekle
Believe it or not,it’s really worked after 10 times of hard smack!Dropped my ipad 2 yesterday and came across this solution!Thanks,God it’s fixed and back to normal now :)
Puan 0
Yorum Ekle
Is this a joke??? I tried this - nothing happened except that my hand hurt
Puan 0
1 Yorum:
No, try dropping it. Preferably on carpet and not from too high. I thought it was weird too but it worked for me.
tarafından
Yorum Ekle
It worked!! Thank you! I really thought it wouldn’t but it did. Thank you so much!
Puan 0
Yorum Ekle
My Grandfathers iPad has weird colors on it it is kinda of like it is inverted but I can still see the original colors I tried hitting really hard on the back multiple times but it is not working and I hit it every where
Puan 0
Yorum Ekle
Just woke up to my 2020 iPad Pro 12.9 doing the same old TV flickering. Give the back 3 smacks with my palm, good as new again! Thanks!
Puan 0
Yorum Ekle
Yanıtını ekle
Glyzza sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 58
Son 30 gün: 278
Her zaman: 369,934
