Ana içeriğe geç
Xserve is the name of Apple's 1U rackmount line of server computers. When the Xserve was introduced in May 2002, it was Apple's first designated rack-mounted piece of server hardware.
keeps shutting down at night
Our xserve keeps shutting down overnight and needs to be rebooted each morning. We have a spare motherboard that came with the original computer and wonder if you folks would install it or is it easy enough for us to do?
Bu iyi bir soru mu?
Puan -1
1 Yorum
Does it shut down at the same exact time each time?
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
I use to run one of these servers for a local University and never had any issues with it for the 4 years I was using it. If there was anything that came along that was not right it would throw out a warning that created a log entry. Find the log and read what it has done. Also I had it set up to notify me by email of any issues and it would send out one if it was not happy about something. Go to the site Markus Weiher mentions above to set up these functions. Also Make sure you have a large enough power/battery backup on the unit.
It is good you bought the server with the service package with it so you have the spare parts. Did it come with spare fan also? Check to see if all the fans are running. This thing is very loud. If yours is not then the fans could be the issue. Make sure that if you try the replacement board you have someone who is use to working with a static mat so they do not zap the board. Do Not Take It Out Of The Bad With Out Using Grounded Static Strap!!!
Good luck. But learn the Management system for the server before starting to tear it apart to fix what may just be a setting.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
En Yararlı Yanıt
Is there the possibility that it's a software issue? I think of something like a cron job misconfigured or forgotten.
Puan 2
4 Yorum:
what's a cron job?
tarafından
Cron jobs are unix scripts that are called to a specified time. In a server enviroment they are used a lot and that made me think that thats the problem, not a hardware fault.
tarafından
That's along the lines of what I was thinking, software issue, maybe not even an issue. Just something forgotten.
tarafından
The log files will tell you what you need to know. Unix logs just about everything it does.
tarafından
Yorum Ekle
there is a DIY gude on apple.com
http://manuals.info.apple.com/en_US/Xser...
have fun ;-)
Puan 1
1 Yorum:
If you think Software is shutting it down, you can come in on a weekend, disconnect all Network connections (so the internal clock cannot update from a time server) and set the clock forward 8 hours or so. Come back every 2 hours and see if it is still running.
tarafından
Yorum Ekle
It could be temperature related. Many companies, trying to be more energy efficient, shut down the Air Conditioning at night. I would run Console and check your log files. You should be able to see if a chron job or temperature is shutting it down.
If you do not understand what Console is, someone will either need to do some studying or hire a Unix Guru. You may be able to send the logs to Apple Support, if you have a Service Agreement. It is far beyond the scope of this site to instruct how to analyze log files.
If you think it might be temperature related, leave the door to the room the server is in open (put furniture in the way with a 'do not move' sign) or put a cheap box fan (less than $20) where it will blow air on the server and see if it stays up that night. Note: this is a test, not a permanent solution.
Puan 0
Yorum Ekle
Yanıtını ekle
rolf sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 1,622
