Question mark when MacBook turn on?
When I turned on my MacBook, a question mark pop up without the apple logo or the spinning wheel?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Either your HD is trashed, or corrupt. You can boot from your install CD/DVD and run Tools->Disk Utility->Disk First Aid Tab->Repair Disk. (Do not do an install).
If you don't have/can't find your install disk you could try booting into single user mode and running a utility from the command line.
' Startup in single user mode ( hold down command-s after the boot boing ) you'll see white text on a black screen. When it stops loading/scrolling type /sbin/fsck'' press return.
If the above fails boot in target disk (hold down the T key until you see the firewire symbol {looks like a stylized Y}
Good Luck.
N.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,716
