Ana içeriğe geç
Also known as the GS70 Stealth, this 17" gaming laptop was released in summer 2013 by Micro-Star International. Identified by the model number MS-1772.
How can fix my msi gs70 spacebar?
Whenever I click the spacebar on the outer (left or right) edges I have to click really hard for the laptop to register it as a key press. Sometimes no matter how hard I press or if I even hold down the spacebar key it won't register a click. It works fine if I press near the middle.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 9
17 Yorum
My spacebar,Z, and S key arehavingthe same issues
tarafından
Steel series doesn't know keyboard engineering. We are the victims. Ideally Space bar should contain 3 sensors [left , mid, right]. We have to suffer because we chose MSI and MSI has chosen Steel series and Steel series has chose an engineer lacking common sense.
tarafından
http://xoticpcforums.com/showthread.php?...
well known common manufacturer defect
you can mitigate it, but you may not be able to fix it. The mitigation involves opening the case and inserting something to protect the cable where it wraps over the motherboard, passed an unused connector.
tarafından
I have the same laptop but in additon to the spacebar my "s" and "z" buttons are not working properlly. They don't work at all or they do more instertion than intendet whcih ressults like this; zzzzz sssss ech. thanksss, zzzero and multiple space touchs.
Any sugestions?
tarafından
I have the same issue, but it only happened when I upgraded to windows 10. Were you able to find a solution?
tarafından
12 tane daha yorum göster
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I noticed similar issue, and fixed it by:
1. Carefully pop out the space key. (I use may nails)
2. Turn it over, glue a piece of paper to the center of the key. Size like 5mm x 5mm. I used high quality printing paper. (I also tried using business card paper, but it was way too thick)
3. Push space key back to the keyboard.
Bu yanıt yardımcı oldu mu?
Puan 5
5 Yorum:
In 2016 it's still valuable solution!
tarafından
I also got a brand new one of these msi laptops in *2018* with the crappy steelseries keyboards. opened it up and replaced the ram and SSD so i couldnt return it. did the folded paper trick, works 100% now.
same problem with these keyboards since 2014? MSi should probably figure this out LOL
tarafından
How many times do you fold the paper?
tarafından
Spend nearly two thousand on this laptop and had to stick paper under the space bar.. I really don't care because it's working amazingly now. Thanks for saving my butt.
tarafından
I bought an MSI machine 2 years ago and although it was a good deal and a good gaming machine, it drove me nuts that spacebar didn't work at the edges when trying to use it to type instead of game. I've put up with it for 2 years and just now did this fix - it works great!!
Really sad that this has been an issue since 2014 and I can see from recent comments that it's still not fixed in 2019. I assumed it was a new keyboard design that was badly engineered the year I bought it, but to produce this crap 5 years in a row and not fix it?? Steelseries and MSI should be ashamed. No idea how this passed QC the first time, least of all 5+ years in a row with the same terrible flaw. You'd think testing for a working spacebar would be the most basic of quality control tests.
Well at least the fix is easy. I used a piece of scotch tape instead of paper, since it has built in stickiness, just doubled it up to be about the same thickness as a piece of paper. Works great now! Thanks for sharing the fix!
tarafından
Yorum Ekle
I had this problem, i bought some double sided sticky pads i had laying around and without removing the space bar carfully lifted it just enough to push the pad inbetween the white plastic thing and the spacebar key cap itsself it doesnt look any different and works just the same but without the miss click :) hope this helps !
Puan 2
Yorum Ekle
Inserting a piece of paper between the spacebar and the button seems to have worked for me. I folded the paper over the end of a credit card and used the credit card to both pry the spacebar upwards slightly and simultaneously push the paper in.
I also have a fairly recent laptop: MS-16K3 with a GeForce GTX 1070. Bought about March 2018.
Puan 2
2 Yorum:
tarafından
Same here, spent nearly £1500 on MSi Leopard GP73 8RE and Spacebar is the worst I have ever come across. I have used the paper / credit card technique and this seems to have solved the issue. ..... Nomoreofthiscrap where spaces don't work.
tarafından
Yorum Ekle
MSI GS70 z, s, spacebar,6,7 problem is completely hardware problem. To fix it clean ribbon cable silvery parts must be cleaned by a piece of eraser and fix it to keybpad connector firmly. roblem repeat itself again in time. follow: https://youtu.be/FpVuzisn0-c
Sul Sul
Puan 1
Yorum Ekle
I just wanted to point out that this issue is still present in MSI's newer notebook lineup with the Pascal GPUs. I was able to resolve the spacebar issue on my GS63VR (GTX 1060) using the same technique. Be sure to be very careful removing the spacebar, or any key for that matter.
Puan 1
Yorum Ekle
To get help related to all MSI Laptop then call MSI Laptop Technical Support.
Puan 0
Yorum Ekle
Yanıtını ekle
tomas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 72
Her zaman: 19,208
