Ana içeriğe geç
PlayStation 3 (veya daha sık bilinen adıyla PS3), Sony Computer Entertainment tarafından üretilen üçüncü ev bilgisayar eğlence sistemidir ve PlayStation 2'nin akabinde devamı olarak üretilmiştir. 11 Kasım 2006'da piyasaya sürüldü.
System won't read discs?
The system starts up fine, and I can fart around in the menus all I like, but when I put a game or movie in, it starts to load (in the event of games, it even shows the graphic on the menu), but it stops and powers off. Any thought?
Bu iyi bir soru mu?
Puan -1
3 Yorum
Which version/update? Please amend or add a comment.
tarafından
It is likely overheating OR the power supply is dying (voltage drops below spec). Those are the only two ways I know to force a power down. Could also be an issue in the power control chip.
tarafından
Does the red LED flash before the shutdown?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I would first try to check/clean the laser with a soft microfibre cloth.
use the following guide to disassemble it: Playstation 3 Optical Drive Replacement
but many ps3 lasers are "dying" - never had a "dead" one, but the ps2 had a similar problem and every ps2 i had with that issue, had "burned in" dust on the laser - i've cleaned it and everything worked as normal
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Rick sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 1,775
