Ana içeriğe geç
pump just hums
i have a summer escape pool and the pump just hums what can i do to fix it
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
KATHY, there are a few possibilities. Chance of a bad motor start capacitor ( use a multimeter or capacitance meter to check that) a seized pump motor (unplug the pump and see if you can turn the impeller by hand) or a short on the start winding of your motor. We could possibly give you a bit better info if we would know what make and model your pump is. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
The pump has a tiny plastic fan blade which moves the water thru the pump the blades in your fan are broke replace the punk
tarafından Paylaş
bang on the motor with a hickory stick, it that doesn't start it, it is the capacitor, replace or bearings, then have to replace the dry end or motor. 35 years in Biz
tarafından Paylaş
Yorum Ekle
Most likely is a bad pump motor start capacitor
Puan 0
Yorum Ekle
Yanıtını ekle
KATHY sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 26
Her zaman: 919
