Ana içeriğe geç
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 Soru Tümünü görüntüle
water damage caused screen to go black
my phone still works, but the screen has gone black since spilling a small cup of water on it. sound, text and rings all work and am able to have a phone conversation
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 9
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
VERONIKA K, as with any fluid immersion time is vital to prevent corrosion. Rice will not help you. It does not prevent corrosion and will not repair your phone. Use these guides to disassemble your phone. Use some sterile water and rinse all the part. Use 90%+ isopropyl alcohol and a small brush and clean every part, including the ribbon cables as well as the connector. Pay particular attention to the LCD connector. Check for any missing, burned or charred components. Once it is properly cleaned, let it dry. Then reassemble your phone, and it is possible that you have a shorted backlight circuit. If you are handy with a multimeter, we can give you some testing points where you could check the voltage to see if you have power to the LCD. So you may have to start with a new display assembly.
Bu yanıt yardımcı oldu mu?
Puan 5
3 Yorum:
Where would these test points be located? I am currently working on a device with similar issues. Phone will boot after water damage treatment (isopropyl and ultrasonic) but nothing on the screen. The board components on the screen side under the LCD/digitizer connector looked really rough before the treatment.
tarafından
I did all of this and the display came back on, but then it flashed green and shut back off. At this point it will not come back on. I do know how to use a multimeter if you have further instruction and one is required.
tarafından
I have this same problem with my note 3
tarafından
Yorum Ekle
You might be screwed and have to buy a new display or cable, but try first a bag raw rice for a day or so, if that doesn't work I've founded opening it up, cleaning with ethanol, and drying carefully does the trick.
Puan 0
2 Yorum:
I have the same problem. Took everything apart, and washed it with isopropanol still the display won't work. I can connect it via mini usb to a screen and use my phone but the display is dark. I've scrubbed all of the insides gently with a brush and alcohol but nothing. I've also tried applying heat. Any advice?
tarafından
RICE DOES NOT WORK! Granted it will suck the water out of the phone but will not stop the corrosion of the phone parts.
tarafından
Yorum Ekle
Yanıtını ekle
VERONIKA K sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 23,039
