U2 IC for iPhone 5C replacement
Hi Guys,
Last few days my iphone 5C is acting weird, Its getting hot, Its charging very slow and draining the whole battery in 90 minutes on standby. First few days it was not draining that fast but as mention above now its draining very fast.
I searched many forums and tried many things like deleting exchange, restoring and switching off SIRI but to no vale but one of the person mention that he changed the U2 IC and this resolved the issue. He was very clear that he used non certified iphone charging cable (Which is normal because Iphone battery is not excellent that it last long and you have to get it charge many times and sometimes you do it at your friend house and end up using non certified cable). I did the same and also i find out that IOS 7 + recognize the non certified cable straight away and it is damaging the U2 IC.
Now my questions.
1. What do you think about the issue? You think it is U2 IC problem?
2. I am trying to buy U2 IC but i am not able to find for 5C instead everyone is selling for 5 and 5S. So can we use a 5 or 5S IC for 5C? If not
3. Can you tell me the part name or number for this U2 IC for iphone 5C and the place i can get it from.
Last question is that is it easy to repair the U2 IC. In my country we do not have excellent repair shops and i already check with Apple retailer and they said that they cannot repair this. I still have water damage IPHONE 4S sitting idol in my table where i could not get the power IC changed because no one was able to change it in my city.
By the way i am in Saudi Arabia.
Bu iyi bir soru mu?
5 Yorum
did you replaced the u2 ic already by urself? seems it is not very easy.its too small
mr128 tarafından
i have the same problem with you. draining whole power take 5hour
mr128 tarafından
I am mobile repairer I have change that ic but I am not able to charge my customer phone and I am not getting voltage on battery connector anybody help
quadeer tarafından
Change u2 ic from iPhone 5s they are same and if don't get volatage it could be u2 ic
Crack & Fix tarafından
Wouldnt it be much easier to change the logic board since they are only $30?
Sarah Ybarra tarafından
