Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
iPhone 5s will not power back up
Iphone 5s was submerged in salt water. It was removed from salt water and rinsed/submerged in fresh water to hopefully get rid of salt. It then placed in container of rice for several days. Will not power back up or indicate charging when plugged in. Any suggestions?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
take the board out following the ifixit teardown, once the board is out clean it using alcohol solution(not vodka) then hope leave to dry, put the board in and hopefully it will work, but if anything is corroded or damage, it may need more work
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
Think u just put the nail in the coffin when you tryed cleaning it with water lol
Rice is the worst thing you can do I'm afraid phone needs cleaned out with alcohol and dryed..
When water drys it causes corrosion drying a iPhone out in the worst thing you can do
Puan 1
Yorum Ekle
Need new battery for starters. To check if it is still alive, disconnect battery, then connect to lightning power to see if screen responds.
Puan 1
Yorum Ekle
Yanıtını ekle
paul sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 358
