Ana içeriğe geç
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 Soru Tümünü görüntüle
Soru Kapandı
Galaxy S5 replacement LCD screen not working
I recently cracked the screen on the top right corner of my S5. The screen would not turn on and was unresponsive to touch, however the rest of the phone worked fine e.g. notification sounds, start up etc.
After recently replacing the LCD, the screen is now touch responsive, however all I get is a grey display. I can unlock the phone (as I remember the pattern), therefore the touch is working but the the only display I get is a grey static.
Has anyone had the same issue or have any idea what the problem could be?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
I broke my phone today and am running into a similar issue, the screen is cracked and non responsive, however it is still making notification sounds ect. What did you do to fix your phone? did you replace only the screen or are there other hardware issues?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Either the LCD screen connector get loosen or the LCD screen replacement is broken one itself.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
By screen connector you are referring to the flex cable right? I'm sure that it's connected correctly, it clicks into place. I have taken it out and installed it again several times too.
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 6,629
