Ana içeriğe geç
2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
Any experience with removing moisture from behind retina a screen?
I spilled water on my MacBook. Fortunately after a drying and cleaning treatment everything is working again, but some moisture remained behind the retina screen causing bright stains when switched on.
Does anybody have a tip? I want to try everything before paying for an expensive new screen. I read that turning both fans to maximum speed for a day or so can make the moisture evaporate, but this post concerned a 2008 "ordinary" macbook screen.
Looking forward to your answers!
A
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Probably won't work. All of the Retina Display MacBook Pro models use similar -- and effectively "sealed" -- aluminum and glass case designs of uniform thickness.
The stains will not go away they are likely damaged (possibly corroding) LED's. Start saving now for the replacement display unit. Use the current one until you are no longer able to do so, then replace the unit.
You've learned a valuable lesson about proximity of liquids and laptops.
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Aafke sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 1,236
