Ana içeriğe geç
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
Will not see the USB ports
Mac Pro 2.8 GHz A1186 EMC 2180 Early 2008
Single Quad Core Intel Xeon 5400 10GB RAM
Machine was reported to have had a lightning hit. It tones normally and will boot up to the desktop. I can not get it to see any of the USB ports front or back. Put in a Mac rated new 5 port PCI-E USB card. No luck seeing keyboard. I put a fresh 160 GB hard drive in an identical machine and put 10.5 on it and matched a wireless mouse and keyboard to it. Put the drive in the suspect and it boots fine but the keyboard and mouse are not seen. Does anyone know if the bluetooth has anything to do with the USB? If not the next step I am looking at is replacing the bluetooth board. Since I can't get to a keyboard or mouse, I can't start up from an external HD or optical to run TechTool Pro. Any suggestions? I'm looking at a logic board repair or replacement for big bucks. If I can get to a keyboard, I'd at least have an operable machine. Logic Board part number 630-7997.
Bu iyi bir soru mu?
Puan 1
4 Yorum
Have you tried the AHT?
tarafından
I pulled the hard drive and got it to boot from my external firewire drive with TechTools but can't run It because of the keyboard. Thanks rab, but it's the same story with AHT. Am going out to see if I can find a Firewire to USB adapter since I now know the firewire port is functional.
tarafından
No Firewire to USB adapter in town. There's a possibility that the blue tooth - USB controller has failed but Apple won't talk to me about it. The bluetooth icon fails to show up on boot. My bluetooth dongles are USB. It will boot from internal DVD drive.
tarafından
Update - installed a PCI e USB card I got from Amazon that was rated for Mac and got nothing. Installed a Sonnet Allegro USB PCIe USB 2.0 adapter card and now have functioning keyboard and a working machine. Next, the internet. Have ordered in an airport card as this one appears fried and it shows no ethernet connection. If the airport card fails the I'll order a Sonnet Presto Gigabit PCIe Basic card for ethernet, no more cheap cards from Amazon. Besides it's only $29.00.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Success. I now have an almost fully functioning machine. The only exception is no bluetooth. Bluetooth suggestions are welcome. I installed a Sonnet Presto Gigabit PCIe Basic ethernet card this morning and now have internet capability and access to my network printer. I tried a new airport card with out luck. The Sonnet Allegro USB PCIe USB 2.0 adapter card works for my keyboard and external USB hard drives. The firewire ports work.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
Could it be that a voltage to the motherboard is bad? It is a long shot, but if the lightening shorted some component that is pulling down that voltage, any circuit it powers will not work.
Can you check the voltages into the bluetooth board or out of a USB port?
Do you know if the USBs all send data to the same serial device on the motherboard? I do not know if Bluetooth also feeds the same ASIC. It might (it is a low data rate device).
You will probably need to swap the motherboard.
Puan 1
1 Yorum:
I haven't been able to locate any of the specs on the board or get any info on it at all. But testing the bluetooth for any voltage will at least tell me if it's working. Thanks for the help. +
tarafından
Yorum Ekle
iMac 21.5" Mid 2011 Ram 8GB: My display does not work. Then connected to external display still no display. Then I disconnected LCD and now display turned on.
If I connect LCD then no display on LCD and External monitor.
Now the iMac started and able to goto installation screen. HDD not recognized.
As per the info on a forum disconnected HDD cables and connected again while system was running.
Then HDD recognized and installed Lion. Rebooted few times looks everything fine. One of the application says wrong date and time. Then tried to correct it but I was not able to.
Then I restarted iMac then HDD was not recognized. Tried the same way disconnect and connect the cables from HDD while system running. Still No HDD
Then I tried SMC reset and trying PRAM but system is not taking the keyboard commands, I think
Now when I start the system then it chimes and run for 4 minutes and suddenly restarts for 3 or 4 times and then goto off mode.
Please help me. Thanks in advance.
Puan 0
Yorum Ekle
Yanıtını ekle
mayer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 4,659
