Does replacing the charging port require soldering?
Does replacing the charging port require soldering? If it does, where can I get soldering tools?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Yes. You will probably need a micro-soldering iron. Check with an electronics store. You probably need a good amount of experience in soldering as well.
Bu yanıt yardımcı oldu mu?
You should probably purchase a new motherboard since it is soldered on. It's pretty simple to replace
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 232
