Ana içeriğe geç
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Soru Tümünü görüntüle
iMac works fine without cover, but no video with cover?
I replaced the hard drive in this iMac. No issues. Put cover and glass back on, no video. I take the cover off, and video works fine. I've checked to make sure no cables are pinched or disconnected, all fine. I'm stumped. Any help would be appreciated.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Better check again. As you are replacing the cover you are moving one of the video cables (there's more than one) and losing your signal. You can verify it's not the logic board/VGC or GPU by connecting an external monitor. If that works normally your GPU/Logic board is ok.
You may be shorting the cable as you screw the cover on. Try only using a few screws that are obviously no where near any cables. Also be absolutely certain you are putting the proper length screw in each place - a too long screw may be touching the logic board and either warping or shorting it out.
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
215Solutions sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 102
