Ana içeriğe geç
iPhone'un ikinci nesli. Model A1241 / 8 veya 16 GB kapasite / siyah veya beyaz plastik arka yüzey. Onarımı ilk iPhone'a göre daha kolaydır; tornavida, açma aletleri ve vantuz gerektirir.
iPhone 3G Wi-Fi Not Working - Solution
Hello,
I have some news for the people whose Wi-Fi is not working.
I tried many things and now have more concrete facts about this problem.
My Wi-Fi can't find any networks.
First, I thought that the problem was the Wi-Fi antenna.
On eBay there are many "Wi-Fi antennas". All the vendors tell that this antenna http://www.traderscity.com/board/userpix... handles the Wi-Fi, but it is not the right one.
I disconnected the cable mentioned above and Wi-Fi was still working. Only the GPS stopped working, so the Wi-Fi antenna must be somewhere else.
I think that this part http://www.dealextreme.com/details.dx/sk... handles the Wi-Fi and the 3G. I changed the part, but the phone was still not finding any networks so I thought that the Wi-Fi chip on the logic board may be broken.
I wanted to make another test so I installed the jailbroken app called "mywii". With this app you can open a ad hoc network with your phone. The app works, so the Wi-Fi chip is not broken.
In conclusion, the Wi-Fi antenna and chip are working fine, but phone is not finding any networks. This is very strange. I have no idea what the problem can be, but its not the antenna and not the Wi-Fi chip.
I also tried resetting network settings, as well as updating and restoring the phone, but nothing works.
Bu iyi bir soru mu?
Puan 4
1 Yorum
Hi Robert
How did you install software on your jailbroken iphone when wireless was not working? I have the same issue and dont know how to install mywii to test
thanks
tarafından
Yorum Ekle
9 Cevap
Filtre ölçütü:
Seçilen Çözüm
Ok, let's try to sort it out a little bit.
You wrote about "mywi" - did you actually connect with the iPhone ? (especially - what distance did you have between the device you connected with the iPhone? - and of course - did you try to connect with the router - while you're standing beside the router?)
The first link didn't work - the second one isn't the Wi-Fi antenna
The Wi-Fi antenna looks like that: the connector is number 6 - so check the connection and of course check the contacts. Also, if you bent the connector to much, it could be broken and the result would be no or bad Wi-Fi reception.
Update
I searched my sources a little bit and found a solution posted in a gsm forum by "MPhoneClinic" (the mobile phone clinic from melbourne/australia)
I searched for a larger picture of the PCB and marked the part that you have to change
Resim
So, the good thing is - you know what's defective. The bad thing is - where to get the part and depending on the tools/skills you have, how to replace it.
But maybe you will find a good repair shop in your area who is able to fix it for you.
Bu yanıt yardımcı oldu mu?
Puan 2
10 Yorum:
I made another test:
i disconnected the connector nr. 6 and startet "mywii.
i connected my phone with my mac and it worked fine.
also a distance of 4 meters, didn't change anything. (without the antenna on connector 6.)
Then i put my phone directly near the router (with and without the antenna on connector 6) but the phone doesn't find any network.
that's because i think, that the antenna on connector 6 isn't the wifi antenna.
but why can i connect the phone by using "mywii".
and when i search for a network my phone doesn't find any.
very stange problem.
tarafından
strange but almost common - read my update above
tarafından
Can you post the link of the site you have found? thanks a lot
tarafından
sure - click
tarafından
Can you please give me the direct link to the article. i can't find it
tarafından
5 tane daha yorum göster
Yorum Ekle
Hi! i was having this problem in my 3g and solved it by doing the following..
install bootlace, install idroid, boot in idroid, turn on the wifi - power off idroid boot on ios 4.x..
wifi working.. i tryed everithing else except for the hardware solution and nothing worked (except for the freezer thing.. that worked for some minutes)..
i have wifi working for 3 days now..
Puan 0
Yorum Ekle
The following clever little fix worked for me. I think what happens is the heat liquefies a broken solder point enough to reestablish contact. (I used the hair dryer option): http://www.google.com/url?sa=t&source=we...
Puan 0
Yorum Ekle
hi i am also heaving the same problum but the thing is my WiFi option is in gray light gray colour which means i cant even open it. plz help me out i cant buy an other iphone coz i dont have money
plz if any of you can help plz
my id is
ammarahmed10@hotmail.com
Thank you
Puan 0
Yorum Ekle
The light bulb theory apple releases software updates that have hidden agenda to phase out older models forces us to upgrade to newer products. I've had 7 different 3 gs with the same problem that worked fine prior to os 3 series but after any is higher then that series wifi did not work I find that a bit odd
Update
I meant 3 g model iPhones not "3gs
Puan 0
Yorum Ekle
i have the same problem in my wi-fi my iphone 3gs is not searching any wi-fi network i have checked it on 2 or 3 wi-fi connections but it is not searching any of them plz help me if someone can...
Puan 0
Yorum Ekle
i doubt anyone can answer this but... my iphone 3gs was restored to the whited00r 3.1.3 firmware and now the 3g dosnt work help please
Puan 0
Yorum Ekle
it might look crazy, but I put my iPhone 3g in the freezer for 30 minutes and the Wi-Fi is working, I had tried everything from re setting all that staff no work.
Puan 0
Yorum Ekle
well, If you want to have some minutes of wifi put your iphone into the fridge (cooler) near your frozen things... and in 10-15 min you take it away... you will get maybe 5 min of correct working of the wifi....
Puan -1
Yorum Ekle
Yanıtını ekle
Robert sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 41
Her zaman: 357,801
