Ana içeriğe geç
The third iteration of the 10.1 inch Galaxy Tab tablet.
Colored lines/stripes on screen problem
Hey!
I bought this tablet about 6 month ago, and dropped it accidentally today (2 feet from the ground).
When I boot it up, I can barely see the samsung logo and the flashy animation, I can also see some of the apps/animations of swiping etc. So I guess the tablet still works. Perhaps a misconnection happened when I dropped it.
I watched some videos on how to remove the case, and I did not notice any misconnection :(
Help please?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 8
1 Yorum
I dropped mine few inches and cracked screen. Paid £70 for tempered glass screen. After 3 months it is always bright colours on screen. It would not even work for 2 weeks. Bright yellow screen
Still rang but was no way I could answer it
It's just started to work again but thick black lines to start with and usually ends up pink or blue lines after a while. Do it take to phone shop. Will they be able to fix it without too much expense. Very limited funds. Gem. Hx
tarafından
Yorum Ekle
12 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Probably the display cable got dislodged. Make sure that it is tightly in its socket and see if that causes a change.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
all the cables seem to be connected. Can you locate the display cable and tell me if it is dislodged or not? I have 0 knowledge about hardware and I do not know which cable is which..
tarafından
Make sure that the orange ribbon cable at top and black ribbon cable at bottom are in their slots. If necessary, carefully detach and reattach the cables.
tarafından
Yorum Ekle
Open the tablet, disconnect the video ribbon cable and clean the contacts thoroughly with a stiff brush, being careful not to damage the ribbon cable. Reconnect the video cable, again being very careful not to damage it and being sure it properly seated under the hinged clip. Put your tablet back together and try it now. More often than not this fixes the problem of colored stripes.
Puan 1
Yorum Ekle
==Working but color is all off==
I have had my Samsung galaxy 10.1 for 1.5 years. It still works OK but the color is all off making it look something like a colored negative. No knowledge of miss use or dropping. If I hold each side and apply slightest torque the color returns to normal.
Puan 0
Yorum Ekle
I have the exact same issue as Zeid and Stan!
I have a galaxy tab 10.1 and it slipped from a chair onto carpeted floor, barely a foot.
I've opened it up, pressed all connections in and the display is working again but the colours are all off.
Is there a fix for this?
Puan 0
Yorum Ekle
I have a problem with my RCA tablet and the problem is probably that your lcd is out of its socket or your digitizer is no properly connected
Puan 0
Yorum Ekle
I can't believe the answers I'm reading. You can knock the cable loose by dropping it but you can't change the settings by doing that. It's the LCD that goes bad replacing mine for the second time now after dropping it it's not a big deal there's videos on YouTube
Puan 0
1 Yorum:
But its the cable for some of us. Just fixed it, and it WAS loose.
tarafından
Yorum Ekle
My samsung galaxy A 8 fell down but screen didnot broken but full coloured any solution plzzzz
Puan 0
Yorum Ekle
How to remove vertical colored lines
Puan 0
Yorum Ekle
My Samsung galaxy tab a 10.1 or 8inch is still got alarms going and my music still plays when I press play through my earphones but I can't see the screen at all it's just vertical coloured lines help me please asap
Puan 0
1 Yorum:
Sounds like you cracked the digitizer
tarafından
Yorum Ekle
I've got a problem I've got the same tablet but it looks like this when on still works fine but is disfigured help?
Puan 0
Yorum Ekle
I have an issue. I tried flashing my Samsung Tab A 10.0 SM-T580 and forgot to wipe it clean. Now I have colored lines and cant boot into boot mode. It goes into downloaders mode but that's it. Please help?
Puan 0
Yorum Ekle
we i got come up with ramdon lines on my tabelt
Puan 0
Yorum Ekle
Yanıtını ekle
Zied sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 120
Her zaman: 57,546
