Ana içeriğe geç
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
Can I use Photoshop 7 on this Mac?
I dont really want to spend $700. on the latest Photoshop.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
I believe Photoshop 7 came in both system 9 and system 10 versions. Some disks had both versions on the same disk. See which one you have. I'd call Adobe and give them your old serial number and request an upgrade for $199.00. Be nice and they might do it to keep you as a customer. http://www.adobe.com/products/photoshop/...
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
worth a try +
tarafından
Yorum Ekle
Speaking from experience, the short answer is no. Photoshop 7 actually shipped in only one version that worked with both OS9 and OS X. Thus, it was built on Apple's older language, Carbon. Up until OS X 10.4, Carbon programs could still run natively. However, with 10.5, Carbon support was greatly lessened, and Classic Mode was entirely obliterated. Photoshop 7 relies on many of the functionalities that are not found in 10.5 onwards, so you're pretty well stuck.
If you're committed to running version 7, you might want to see if you can get a cheap iMac that will run 10.4, as Ps 7 will run like a champ under that. I also own Ps 7, and I have found that to be my only choice.
Puan 1
Yorum Ekle
You may work with photoshop files by the medium of damaged photoshop
Read next item http://www.photoshop.recoverytoolbox.com
Puan 0
Yorum Ekle
Yanıtını ekle
samuel eaton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 33
Son 30 gün: 203
Her zaman: 5,357
