Ana içeriğe geç
What kind of Operating System for PowerBook G4?
What operating system compatible for my PowerBook G4?
Bu iyi bir soru mu?
Puan 2
1 Yorum
By using 1.5 GHz Powerpc G4 is best for operating system and i hope discussing on this topic is important. Thanks for your post.
tarafından
Yorum Ekle
10 Cevap
Filtre ölçütü:
Seçilen Çözüm
Highest system is Tiger 10.4.11. I would recommend maxing the memory for that. Ralph
Bu yanıt yardımcı oldu mu?
Puan 7
3 Yorum:
+ Agreed
tarafından
I use a 1,5 GHz PowerPC G4 and it runs OS 10.5.8
tarafından
Yes actually all PowerPC machines with G4 and G5 processors were all discontinued. Your PowerBook can run nearly everything from Mac OS X 10.0-10.5.8 Leopard. Keep in mind since it is an early PowerBook G4 it is not recommended.
tarafından
Yorum Ekle
With such little info, I’ll give you the best information I can. What I’m telling you will be limited in scope, but it should still prove helpful.
Most PowerBook G4's will run Leopard, but it’s not ideal with less then 2GB of RAM as it’s prone to RAM related performance issues. Tiger (10.4) is better on RAM limited systems, but you will also have to deal with crappier software compatibility. Yes, 10.5 (Leopard) works but not well.
For models that are RAM limited (1GB or less), use Tiger for your own sanity. The performance tradeoff is significant and you will be able to tell. Leopard only runs well with 2GB or more, so it only makes sense to deal with the tradeoff if you have 10.5 only software.
Puan 4
2 Yorum:
You could probably get Leopard to run but it would run poorly--I would not recommend it. Ralph
tarafından
Leopard would run fine on 1.5-2GB of ram, however this machine can't take much more than 1 GB. I would not recommend leopard this machine here because of the CPU speed. Panther or Tiger would run great on 1 GB, and decent on 512 MB.
tarafından
Yorum Ekle
The maximum OS you can run is Leopard (10.5.8), however I recommend running Tiger (10.4.11), because Leopard would be a real drag and incredibly slow, with bad performance.
I would also suggest maxing out the RAM, which you can do at 1152MB, however due to slot configuration, the best you can do is settle at 1.0 GB (1000 or 1024 MB), you could put something in the other slot, but it would not be detected, you can get this stick here.
As for the OS, you can get it pretty easily on eBay or Amazon, such as right here, however if you google around there are plenty of Macintosh sites and sellers that have whole archives of every install Disk and will sell to you for a good price.
Puan 3
3 Yorum:
I had Leopard running really smoothly on a PB Titanium 867 with just 1 gig of RAM.
tarafından
For a long while I ran a MacBook with just 1 gig of RAM, slow as @!@% but it worked, and I eventually maxed it out. Define smoothly
tarafından
what operating system? you gave very little information
tarafından
Yorum Ekle
I have book...upgraded ram from 256 to 1.gig of ram...replace the original 40'
hd to a 160..and jumped it from Tiger..to Leopard..10.5.8
runs much better...than it ever did...and for a powerbook that's 8 yrs old,
that's great..and it still turns heads...
Puan 2
Yorum Ekle
I once had a PowerBook Titanium 867 with 1 gig RAM and it ran beatifully with Leopard.
Puan 1
Yorum Ekle
According to Apple-history.com. the max is OSX 10.5.8
Puan 1
Yorum Ekle
If you have a slow PowerBook, I suggest you use OS X 10.4.11, as it is the fastest with older mac's. If your mac has more than 2 gb of ram, then it is probaly OK to upgrade. If you are simply upgrading to get a better dock and theme, you should get ShapeShifter and ClearDock at: http://shapeshifter.en.softonic.com/mac or http://unsanity.com/haxies/shapeshifter
Puan 1
Yorum Ekle
I have been using Leopard on my 12'' pb with maxed out 1+256GB ram. Did not go with Tiger due to the lack of time machine support. Everything is responsive. I am missing a good browser tough. I tried all G4-optimized firefox versions, but none of them can beat camino and Opera. Overall it makes a great travel laptop.
I also tried yellowdog and ubuntu, but they both lacked HW support. I would love to have linux on this machine, but it will never happen, I am afraid.
Puan 0
1 Yorum:
Here is a link to some articles which may help you. Good luck.
http://lowendmac.com/linux/index.shtml
tarafından
Yorum Ekle
I say Leopard some linux distros may also work
Puan 0
Yorum Ekle
Mac OS X 10.5.8 Leopard is the maximum OS for all PowerPC machines with the G4 and G5 processors.
Puan 0
Yorum Ekle
Yanıtını ekle
Jeovel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 30,352
