Ana içeriğe geç
Machine-readable instructions that direct computer processors.
Soru Kapandı
Error message during JAVA update 7 OS 10.5.8 Software
This may not be something this forum can answer but I am getting the following error when attempting to update JAVA on my MacBook (others computers working fine) .
Error:
Installer could not create the folder "/private/tmp/JAVAForMacOSX10.5Update7.pkg.3151331d7UI"
Also, I tried to update Excel and got this error:
Installer could not create the folder "/private/tmp/OpenXML_all_fonts.pkg.30490Lf9KAV"
BTW, I recently had to recover this laptop using time machine after installing Norton Internet Securities which then locked out my ability to use Safari.
I couldn't uninstall it so I simply wiped the HD and used a recent time machine backup just prior to installing Norton.
Any clues as to what is happening?
Do I simply need to re-install OSX 10.5 from the disk and then go thru the updates?
Or
Make a time machine back up, wipe the HD and then re-install the OS from the disk, then drag over my user files?
Bu iyi bir soru mu?
Puan 0
2 Yorum
Repair of permissions did the trick. Thank you Gabe. Never had to try rj713 recommendation.
tarafından
If the answer helped you solved the problem, please press "Accept answer" to file this under resolved, thanks!
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try to repair permissions via Disk Utility, as this seems like a permission issue.
While your at it, try repairing the disk.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Hi, When I had problems with my 10.5 install Apple had me reload the 10.5.8 combo update. Worked for me. It appeared something did not load correctly when I first loaded the update.
I am including the link for you if you want to try it. ralph
http://support.apple.com/kb/DL866
Puan 1
Yorum Ekle
Try reloading the 10.5.8 combo update.
Puan -1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,150
