Remove a stripped lens mount screw from Nikon 300mm f/4.5 AI-s lens?
I'm trying to remove the lens mount, so that I can disassemble and clean a vintage 300mm lens (something is on the interior elements--possibly oil from an ill advised attempt to lubricate a sticky focus mechanism) . Problem is, the screws holding the lens mount on are JIS, not phillips, and one of them is now stripped--the stripped screw is size 00. The other screws are can be screwed out quite easily with JIS screwdrivers. Tried the rubber band trick.
Bu iyi bir soru mu?
