Windshield Wipers Stopped Working on a 2004 Buick LaSabre
We went to see if it might be a relay but it doesn't have one. Could it be the motor?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Daisy Smith, yes it could be. It could also be the switch. I suggest that you check the fuses first. It should be in the under the hood fuse box. Fuse is labeled WSW and should be the third fuse from the bottom up on the first column from the right. Post a picture of your fuse box so we can double check that. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 87
