Ana içeriğe geç
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
Any help identifying iPhone 4 (CDMA) component?
Does anyone know which smd component this is?
It's in an iPhone 4 (Verizon - CDMA) that sustained some water damage (which I cleaned). Following this the camera simply wouldn't work anymore, leading me to assume it could be this component (due to how corroded it still is after cleaning board).
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
1di0t (;-), that is reference designator L11, which is a 3-terminal Filter, SMD Array and it is used for noise removal from high-speed signal lines. A TDK MEA1608PH270T would be a good match. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Found it. Thank you very much man!!
tarafından
Yorum Ekle
Yanıtını ekle
1di0t sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 185
