All pictures are black
When I take a picture it is black. If you turn on the screen shot it is also black
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Heres some of the things i would recommend in addition to iApple:
- Make sure the battery is in.
- Make sure the battery is fully charged.
-Make sure the camera is in one of the automatic settings where it is point and shoot.
- Use your flash?
Bu yanıt yardımcı oldu mu?
Hey Nicole,
Here are some things you can try:
-Check if you are in aperture mode.
-Try a different memory card.
-Change the exposure compensation.
-Check if you have a faulty lens.
-Change your lens.
-Check if you are using a non-ai, ai or ai-s lens
-Check to see if your shutter is going bad.
*Hope This Helps*
Take the lens of and shoot at a low speed such as 1s. Does the shutter open? do you get a white image?
yes_
Try a different aperture and a lower speed with the lens on.
no_
your shutter has a problem or the battery is low!
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 633
