Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
5S Finger Scanner Tear Down
Has anyone attempted to replace the metal ring around the finger scanner?
I was unable to find any info on this, I'd like to offer this as a custom service, I'd be great to get some guidance without wrecking a few of em first.
I think a gold metal ring on a black scanner would be nice ;)
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Andrew, just because the part is available does not mean that it can be replaced without sequela. The touch ID sensor is designed to be secure and it is uniquely paired with each specific phone. There is no way to restore that particular function. Read more about that on here. and on here as well. "unique logic board in each iPhone 5S and the fingerprint data is stored on the A7 chip" I am with Tom and con, don't do it. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
thanks for providing an informative answer OldTurkey!
tarafından
Yorum Ekle
You WILL destroy the sensor and once you destroy it you will lose Touch ID FOREVER, don't ever attempt it.
Puan 1
Yorum Ekle
No it cannot I would just let this idea go..
Is it worth destroying someone's touch id?
Puan 0
3 Yorum:
im not going to wreck a customers, you can order the assembly for around $25, just hoped someone had tried before I delve into it. thanks for the advice....?
tarafından
Shows how much you don't no bout iPhones once a touch scanner is broken A replacement will only let you click the button but it will lose touch id
tarafından
you can purchase replacement finger scanners, this isn't alien technology, its a placeable part.
tarafından
Yorum Ekle
Yanıtını ekle
Andrew sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 262
