Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
HELP! iPhone was drowned, Home button stopped working.
Last morning, I dropped my Iphone 5s into the water for 1 second.
I turned off it and started to disassemble it.
The water even couldn't get into the motherboard side.
Everything seemed fine except the Home button.
1. My Iphone was dropped into the water
2. The water even couldn't reach to the motherboard.
(Only one of three water indicator turned to red)
3. Everything seemed fine except home button.
4. It's not working, but the touch id function is working.
What should I do with it...?
I don't want to loose both touch id feature and home button function...
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
check the home button connector and the charger port flex slot it plugs into for corrosion, and cleaning that with isopropyl alcohol, if that doesent work next step would be new charger port , final step is new home button, but a new home button will lose touchid function no matter what
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Kimbell sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 97
