Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
My screen looks dark and shadowed around writing
I replaced my LCD with a genuine apple LCD from this site, when i connected it everything seemed fine, but when the key board comes on screen it looks extemely dark, you can see the letters but not the gaps between each of the letters. Also on the icons on the home screen the write i.e 'messages' 'contacts' seems to have a dark haze around them that fades out into the background. Can anyone please help??
Thanks
Chris
Update
look at the text under the icons, the screen seems dark in general.
Thanks
Update
Here is what the connector clips look like, can anyone spot any problems?
Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Could you post pics sounds like a bad lcd
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
I've tried the old LCD aswell same problem.
tarafından
You would need some1 with board repair experiance
tarafından
Ask Jessabethany on this site
tarafından
Yorum Ekle
If it's the same with both screens then it's not a screen problem .
Check on the motherboard were the lcd connects and see is any of the pins damaged
Puan 0
3 Yorum:
They doesn't seem to be anything damaged
tarafından
If the connector clips on the iphone or damaged how do you repair them?
tarafından
Do you know of anyone who can repair this problem?
Thanks
tarafından
Yorum Ekle
Yanıtını ekle
Chris Roberts sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 7
Her zaman: 182
