Powers on apple logo. that is as far as it gose
I pad gen 1 powers on to the apple logo, that's as far as the i pad will go. How can I fix it?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I'm having the same problem, I think the cable between the LCD and mother board has a short in it?
Bu yanıt yardımcı oldu mu?
Are you having issues with the LCD Cable?
I can turn it on as long as the LCD cable is disconected.
Hey Joe,
I recommend that you try to do a reset or restore your iPad.
To attempt a reset (Which will not erase your device):
-Hold the Sleep and Home button down (together) for about 10 seconds until the apple logo reappears.
To attempt to restore your device (which will fix your iPad but erase all your data) :
-Connect USB cable from your computer to your iPad.
-Press and hold the Home button down.
-Continue holding the Home button while iTunes is open.
-You should see "iTunes has detected an iPad in recovery mode"
-Use iTunes to restore iPad.
-This should get your iPad working again.
-Be patient because restoring could take a while.
*Hope this helped*
Hey Joe,
I've already responded to a similar question you asked, please try those options.
Ipad gen 1 power on to the apple logo. It get frozen..
*Hope this helps*
I had the same issue, I replaced the battery .
That solved the issue
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 230
