Ana içeriğe geç
Released at 2013, September. Display size - 480 x 800 pixels, 4.3 inches. Internal memory - 4 GB, 1 GB RAM. CPU - Quad-core 1.2 GHz Cortex-A5, GPU - Adreno 203
Why can I not increase the brilliance or back light
i have fitted a new screen and digiliser assembly and all is working i have reset to factory settings but the problem is the back light or brilliance is very dim i have gone into settings and it is on maximum setting i have also tried on automatic setting no differance can you help
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
can any one help
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hey grout705,
Did you try to change the backlight screen timeout, go to Settings - Display - Sleep. Then choose the screen time out duration.
You can also tell the phone screen to always stay lit when it is plugged in via USB. Go to Settings - Developer Options. Then check Stay Awake.
-If you tried those please comment to let me know.
*Hope this helps*
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I have the same problem...
Changed the digitizer and lcd unit, all works fine (after a terrible 10.000 times of in and out) but now the backlight is very dim.. Did everything you said but still no solution
tarafından
Yorum Ekle
Yanıtını ekle
grout705 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 703
