Ana içeriğe geç
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117 Soru Tümünü görüntüle
Need to run bootable copy of desktop on storage to my iBook.
I want to copy my bootable copy from my old desktop to my iBook. When I change the startup disk preference to select the LaCie the iBook ignores it.
The desktop crashed (poor old eMac) and I can't find my system disks for the 10.4.
I made the copy of my hard drive on the LaCie with Super Duper before it died. Super Duper assured me that I had made a bootable copy.
Now that I need the LaCie to boot the Laptop (so I can copy my stuff from the desktop to the laptop) - it won't.
The LaCie is running 10.4.11 and the iBook is running 10.3
I bought the laptop as a notebook to carry when I went to get coffee. I never thought it would have to be the mainstay for my house.
Does anyone have an idea as to how to block the 10.3 on the laptop and allow 10.4 to take over from the LaCie.
Sad story, but true. I lost 15 years of work when my office computer and the hard drive both melted on the same day. Neither disk was recoverable. $2000 went down the tubes with the work.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
did you press the option key right after you powered on the iBook and selected the firewire drive ? - that would be the normal way to start from the FW LaCie
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
You can boot from your LaCie, sometimes it can be tricky on older machines running PPC.
First
-reset the Open Firmware
-Start the computer holding down "command" , "option" , "o" & "f"
-when the text shows up type "reset-nvram"
press enter
-then type "reset-all"
press enter
The computer will restart, hold down "option" and make sure the LaCie is plugged in to the iBook. You should now see your LaCie as a startup disk. select it and press enter to boot from the drive.
..done & done..
Puan 0
Yorum Ekle
Yanıtını ekle
David sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 826
