Ana içeriğe geç
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Soru Tümünü görüntüle
Salt water on dock connector
My iPhone 5 got splashed with salt water.
It still works, but a message about compatible device keeps displaying, which leads me to believe that salt water got on the dock connector.
I powered it down. Any suggestions on what to do next?
My wife suggested swabbing the inside dock connector with rubbing alcohol. Would that work?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
it would defiantly help, it sounds like the contacts are getting shorted out, i would recommend a higher percent alcohol like isopropyl witch is 99% + alcohol, drys better as it has less water than standard rubbing alcohol, if that doesn't fix it you could try a new charger port
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
swap it quick, the sooner the better... make sure it's dry when you plug it in.
Puan 1
4 Yorum:
Thanks, Michael and iwillfix. I'll do that next.
tarafından
no problem. don't wait to long, salt water damages the copper pins...
tarafından
Thanks, I swabbed the contacts with denatured alcohol and put it back into the bag of rice. I'll give it a try tonight to see how it runs after 48 hours of being in rice. I'll also open it up to see where there might be salt damage if salt water got inside beyond the contacts.
tarafından
Don't waste your time by putting it in rice. That doesn't really help.... you could open it up to check for damage. But i would already try if it works..
tarafından
Yorum Ekle
Yanıtını ekle
glenn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 115
