Ana içeriğe geç
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
969 Soru Tümünü görüntüle
Toshiba Satellite A100 Screen not working, even on external monitor
The screen on my Laptop just stopped working, with no warning. the computer is on but the screen is black and won't even project on and external monitor. Is this fixable or is it just done?
Bu iyi bir soru mu?
Puan -1
1 Yorum
It's a Toshiba Satellite A-100
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Do you know if it has a graphics card, or just a graphics accelerator on the motherboard?
If it has a separate graphics card, and if the laptop supports it, it can potentially be replaced. You should check the laptops specs and documentation.
If it just uses an on board graphics accelerator, then the issue is a bit more severe, I don't know what Toshiba's replacement part availability is, but you may be out of luck if this is the case.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thanks I'll look into it. that's a big help thanks!
tarafından
Yorum Ekle
Yanıtını ekle
Michael Clements sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 3,146
