Ana içeriğe geç
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Soru Tümünü görüntüle
After turning the iMac on, all I see is blue.
After the power went off one night I tried restarting the computer the next day and it went smoothly past the first part where you see the apple but right afterwards it came to a blue screen and that's how it stays.
I've tried turning it off and turning it back on but that didn't work. I also tried leaving it for a few hours but all it did was flicker to a light blue then a faded blue.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sounds like it corrupted the system software. Try holding down the Shift key on start up. Next startup from your original system installation disk, hold the C key down. Run Disk Utilities on the hard drive and repair it then give it a try and let us know your results.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
It worked!
Thank you so so so much!!
tarafından
If you accept this answer it can be used to help others.
tarafından
Yorum Ekle
Yanıtını ekle
Jasmine sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 72
